laratta
#1 Posted : 10 years ago
laratta
The LED seem to stuck at number 19, and Rinse Only option with the light blink. This indicate that the Rinse Aid is low. Try to hit Start/Cancel button, and also reset the circuit breaker, but I still can't select other option, such as "Normal Wash", "eco wash". None of these button work. Does low Rinse Aid cause the rest of the option not working? I don't need to use rinse aid, since my water is clean. Is there a manual reset option, since I already tried to reset the breaker, and hit Start/Cancel? Or is it the sign of bad control panel, that need to be replace? The only message is, "19", and it stuck at "Rinse Only" mode. Thanks a lot in advance,
Laratta
laratta
#2 Posted : 10 years ago
laratta
Anybody have any idea?
