I have a natural GAS goodman furnace, its new and it just stopped working. the led light is continuios and still don't do nothing, but if you pull the fuse out of the circuit board then the inducer starts up and the led blinks 6 times signaling an open rollout. put the fuse back in and the led stays on steady and it wont do anything, it is very puzzling? any ideas? anyone ever see that please let me know. thanks
A Furnace would be used in a better way, if and only if that has a good heating practices. Then only there will be less possibility of getting a furnace damaged. So, to improve your heating practices and to get a better solution over it, please consult a professional heating solutions provider.
