Jeremy8
#1 Posted : Saturday, February 21, 2015 5:22:54 PM(UTC)
Jeremy8
I am trying to find out what to troubleshoot next. The washer was working with one load and on the next it did not fill with water. The water drained properly from the load before. I thought the valve might have been stuck or defective but the screens were clean and it wasn't receiving 120v. current. I tested it on it's own by supplying outside sourced current to it and it is working as it should. Everything else seems to be functioning. The Timer continues to go through each cycle till finished. the motor, transmission, pump, agitator all function through the cycle but I am no longer getting 120v. current to the valve when I should. What would be next in line to trouble shoot? Thanks
fairbank56
#2 Posted : Saturday, February 21, 2015 6:49:26 PM(UTC)
fairbank56
Groups: Expert
Well, it shouldn't be agitating with no water in it. That would indicate a defective water level pressure switch. If it's not really agitating without water, could be a problem with the water temp switch or the timer. Would need to see a photo copy of the wiring diagram. Open the control panel for access to the diagram.
Eric
