My Kenmore Elite just began a constant drip leak underneath. Appears to be coming from the incoming water source (looks like just above it). When I turn off the water source it stops, so it doesn't appear to be from the previous load. Trying to attach photo... Thanks for any direction. jsciarrino attached the following image(s):
You did not include a model number so I cannot help with a part number but I would say that the water valve is leaking and should be replaced. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  You did not include a model number so I cannot help with a part number but I would say that the water valve is leaking and should be replaced. Hi Denman, thanks for the reply. Not sure of the model # but you're right, it was the water inlet valve (part #W10648041-KM). Removed it with the water supply still on an a pin hole in the plastic squirted a nice stream right into my eye:) $40 repair without having to call service, I'll take that. Thanks again.
