jsciarrino
#1 Posted : Saturday, February 14, 2015 1:20:50 PM(UTC)
jsciarrino
My Kenmore Elite just began a constant drip leak underneath. Appears to be coming from the incoming water source (looks like just above it). When I turn off the water source it stops, so it doesn't appear to be from the previous load.
Trying to attach photo...
Thanks for any direction.
jsciarrino attached the following image(s):
#2 Posted : Sunday, February 15, 2015 2:55:50 AM(UTC)
You did not include a model number so I cannot help with a part number but I would say that the water valve is leaking and should be replaced.
jsciarrino
#3 Posted : Sunday, February 15, 2015 5:40:47 AM(UTC)
jsciarrino
Hi Denman, thanks for the reply. Not sure of the model # but you're right, it was the water inlet valve (part #W10648041-KM). Removed it with the water supply still on an a pin hole in the plastic squirted a nice stream right into my eye:) $40 repair without having to call service, I'll take that. Thanks again.
