AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag Performa heats on one cycle, not others
This dryer recently stopped heating on the "More dry / Less dry" cycle. But it will still heat up on the Timed Dry cycle. How can we figure out what is causing this, so we can start using the non-timed cycle again?
Here are your parts, includes a wiring diagram. Parts for Maytag PYE3360AYW Dryer - AppliancePartsPros.comSet the timer to where you do not get heat. Unplug the unit. Set your meter to the most sensitive resistance meter scale. Short the meter leads together before starting to see if the meter has a zero offset. Now measure L to H on the meter it should be 0 ohms. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
