Maytag2015
#1 Posted : Saturday, February 7, 2015 6:14:51 PM(UTC)
Maytag2015
This dryer recently stopped heating on the "More dry / Less dry" cycle. But it will still heat up on the Timed Dry cycle. How can we figure out what is causing this, so we can start using the non-timed cycle again?
#2 Posted : Sunday, February 8, 2015 2:48:48 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Maytag PYE3360AYW Dryer - AppliancePartsPros.com
Set the timer to where you do not get heat.
Unplug the unit.
Set your meter to the most sensitive resistance meter scale.
Short the meter leads together before starting to see if the meter has a zero offset.
Now measure L to H on the meter it should be 0 ohms.
