nmesllc
#1 Posted : Monday, October 26, 2009 4:08:02 PM(UTC)
nmesllc
When The Start Button Is Pushed, Only
Hums, Drum Does Not Move, It Had
Been Working Great Until Then.
SublimeMasterJW
#2 Posted : Monday, October 26, 2009 4:59:34 PM(UTC)
SublimeMasterJW
Could be some worn out slides.
Bad drum glides(red arrows) make weird noises sorta like bad rear brake shoes on a garbage truck or bus; the plastic
slides and the bearing itself will wear out and the drum will hit the dryer door housing and eat down into it. Seen it.
UserPostedImage
Start here:
UserPostedImage
