When The Start Button Is Pushed, Only Hums, Drum Does Not Move, It Had Been Working Great Until Then.
Could be some worn out slides. Bad drum glides(red arrows) make weird noises sorta like bad rear brake shoes on a garbage truck or bus; the plastic slides and the bearing itself will wear out and the drum will hit the dryer door housing and eat down into it. Seen it. Start here:
