Fridge is 2 years old not my ice maker is not working. Ill get maybe 8 ice cubes in 24 hours. There is a place for a filter in the fridge for the water and ice but I have never used it still has the dummy plug in it. The water dispenser on door seems to run slower then it did. I notice that there is a tube running up the back of the fridge to some small box then into the freezer. Not sure what that is. Could the water line in the fridge become kinked Thanks Rick
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Ive just installed a regular compressor in a LG LMXS30776D and Im having a hard time finding DC voltage that shuts off when the temp is met? I have a solid state relay that can use 3v to 32v dc to switch 110v for the compressor, I have tried numerous combinations of wires on the board, even what I presume is the cond fan, to get voltage but all of them stay on and do not shut off when temp is reached??
Rank: Guest
Rank: Guest
Rank: Guest
LG trio refr. I/m will not fill automatically but will fill if you manually cycle with test button. Ran test procedure to test bin sensors and checks okay. Unit sold by Sears 795.72053112.
