Sam F
#1 Posted : Thursday, January 22, 2015 6:21:57 AM(UTC)
Sam F
The washer will go through all cycles just fine and it does agitate, but it won't spin. I did a continuity test on the lid switch and it passed and just to be safe I also bypassed the lid switch and still won't spin. I also replaced the timer and still won't spin. I can hear the motor running and as I said it will agitate, but just won't ever spin. What could be the problem?
Thanks,
Sam F :(
sidfink43
#2 Posted : Friday, January 23, 2015 12:56:21 PM(UTC)
sidfink43
The textbook says that when you have spin problems on these models you replace the thrust bearing, this part here.
Part number: AP4009132
and as difficult as it is to believe, in this case the textbook is usually right.
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Maytag Bravos washer won’t spin - weird noise (Washer Repair)
by Helpwithmywasher 12/25/2019 2:01:44 AM(UTC)
washer/dryer combo washer won’t spin (Washer Repair)
by Bill.grieves 3/21/2018 4:08:25 PM(UTC)
Kenmore front loader washer won’t spin (Washer Repair)
by Bob Watts 5/16/2009 6:25:03 PM(UTC)
