This is not a new problem, but I'm just getting around to fixing it now. The ice dispenser will only dispense crushed ice. I know this is a common thread, but my problem is different in that this particular model generates crushed ice or whole ice cubes by reversing direction of the auger motor. I can select crushed ice, and it works fine. But when I select the whole ice button, the indicator above the membrane switch will light up-but no ice will dispense. The motor does not even hum. Could this be a dead motor? Is it possible to only die in one direction? Sure would appreciate any help in diagnosing this issue. Thanks.
No comments or suggestions? This cant be the only time this issue has come up... Or maybe I'm just THAT lucky..
