Bstidd
#1 Posted : Thursday, January 15, 2015 8:59:13 AM(UTC)
Bstidd
This is not a new problem, but I'm just getting around to fixing it now. The ice dispenser will only dispense crushed ice. I know this is a common thread, but my problem is different in that this particular model generates crushed ice or whole ice cubes by reversing direction of the auger motor.
I can select crushed ice, and it works fine. But when I select the whole ice button, the indicator above the membrane switch will light up-but no ice will dispense. The motor does not even hum. Could this be a dead motor? Is it possible to only die in one direction?
Sure would appreciate any help in diagnosing this issue. Thanks.
Bstidd
#2 Posted : Wednesday, January 21, 2015 8:44:16 AM(UTC)
Bstidd
No comments or suggestions? This cant be the only time this issue has come up... Or maybe I'm just THAT lucky..
