tdetwiler
#1 Posted : 10 years ago
tdetwiler
No heat! Changed heating element, thermal fuse, and the thermostat. Still no heat from dryer. Any thoughts on what else it could be?
#2 Posted : 10 years ago
Your model number seems to be missing a couple digits.
I tried the Sears parts site but nothing came up.
Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
I would check the power.
The heater requires the full 240 volts but the motor etc. only need 120 volts, at least on most units it is like this.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Dryer tests good but stil no heat!!! (Dryer Repair)
by Aaron Chesler 9 years ago
New Parts and still no Heat!!!! (Dryer Repair)
by larosa00 13 years ago
No HEAT!!! (Dryer Repair)
by Charley Albert 14 years ago
No heat!!! Please help! (Dryer Repair)
by importtek 14 years ago
i have no heat!!! (Oven Repair (including Ranges and Cooktops))
by timwalls 15 years ago
