jrhyan
#1 Posted : Monday, October 26, 2009 7:59:15 AM(UTC)
jrhyan
Following apparent power surge (clocks were blinking) screen reads "OFF" and oven doesn't work. clock is on but none of the controls work. Range is fine. ERC?
Jack
#2 Posted : Monday, October 26, 2009 3:47:47 PM(UTC)
Try to reset the power.
What happen if you depress any button?
jrhyan
#3 Posted : Tuesday, October 27, 2009 8:15:38 AM(UTC)
jrhyan
We tried resetting the power (threw breaker for 30 seconds) a couple of times. It didn't help. When you depress the "oven cancel" button, it makes a beep. Nothing happens when you depress any other button. The screen shows the clock (can't program it) and "off."
#4 Posted : Tuesday, October 27, 2009 2:24:54 PM(UTC)
Most likely the problem is a bad ERC but there is a small chance for the control panel to be bad as well.
ERC is expensive but it is still available while the control panel has been discontinued by the manufacturer. I really do not know what to recommend in a such situation.
- The ERC Part number: AP4041780
