Following apparent power surge (clocks were blinking) screen reads "OFF" and oven doesn't work. clock is on but none of the controls work. Range is fine. ERC? Jack
Try to reset the power.
What happen if you depress any button?
We tried resetting the power (threw breaker for 30 seconds) a couple of times. It didn't help. When you depress the "oven cancel" button, it makes a beep. Nothing happens when you depress any other button. The screen shows the clock (can't program it) and "off."
Most likely the problem is a bad ERC but there is a small chance for the control panel to be bad as well. ERC is expensive but it is still available while the control panel has been discontinued by the manufacturer. I really do not know what to recommend in a such situation. - The ERC Part number: AP4041780
