My Whirlpool Cabrio dryer seems to over heat and puts out high temps no matter what the temp setting....high , med , or low . I've checked the whole vent system and the blower , as well as the inside of the cabinet and have found no problem . Is there a temp thermostat or temp control which may have gone bad and needs replacing ? thanks
Here are your parts Parts for Whirlpool WED6200SW1 Dryer - AppliancePartsPros.comSee the attachment for the tech sheet. Yes there is a thermistor that can be checked, see the tech sheet. The first thing I would check for a grounded element. Unplug the unit and both wires from the element. Measure across the element, should be 8 to 12 ohms. Then measure from each side if the element to it's cas, both should be infinite ohms. If not the element is grounded and should be replaced. |
THIS FORUM IS DEAD!!!!!!! |
thanks for your help and tech info , Denman . Stash
thanks for your help and tech info , I'll check the heating element for grounding . Stash
Originally Posted by: Stash thanks for your help and tech info , I'll check the heating element for grounding . Stash ( this looks like more than 10 characters to me , but the website keeps kicking it back to me ! )
Originally Posted by: Stash thanks for your help and tech info , Denman . Stash I'll check the heating element . Stash
