mlovelace
#1 Posted : Thursday, December 25, 2014 9:26:27 AM(UTC)
mlovelace
Hello
GE Monogram ZET857 double oven - Top oven will come up to the set temperature and hold the temperature, but if the set temperature is changed then it may turn off. Bottom oven works fine.
I changed the Thermostat for the Top Oven but that did not fix the problem
Any thoughts on what is wrong, diagnostic steps or how to fix the problem?
mlovelace
#2 Posted : Monday, January 19, 2015 6:15:22 AM(UTC)
mlovelace
Bump....Still need help here
