Hello
GE Monogram ZET857 double oven - Top oven will come up to the set temperature and hold the temperature, but if the set temperature is changed then it may turn off. Bottom oven works fine.
I changed the Thermostat for the Top Oven but that did not fix the problem
Any thoughts on what is wrong, diagnostic steps or how to fix the problem?
Bump....Still need help here Thanks
