I need a new crisper drawer. It say on the drawer: # 2163836 VENDOR 05448. the model # label has been removed. can any one tell me what part number I need?
I cannot find any info using the given numbers. With luck someone else will have more success.
All I can suggest is that you find other parts with numbers on them. Then look theses up on AppliancePartsPros. If you find the part there is often a listing of what models that part is used on. You could then look up that model to see if it is tha same as yours.
If you find a unit with drawer that looks the same then perhaps using the picture of the part and the squares which are 1 inch may help you confirm that it is the correct size. |
THIS FORUM IS DEAD!!!!!!! |
