jejones007
#1 Posted : Wednesday, December 24, 2014 2:21:32 PM(UTC)
jejones007
I need a new crisper drawer. It say on the drawer: # 2163836 VENDOR 05448. the model # label has been removed. can any one tell me what part number I need?
#2 Posted : Saturday, December 27, 2014 1:59:05 AM(UTC)
I cannot find any info using the given numbers.
With luck someone else will have more success.
All I can suggest is that you find other parts with numbers on them.
Then look theses up on AppliancePartsPros.
If you find the part there is often a listing of what models that part is used on.
You could then look up that model to see if it is tha same as yours.
If you find a unit with drawer that looks the same then perhaps using the picture of the part and the squares which are 1 inch may help you confirm that it is the correct size.
