reply to previous thread on 12/23 left some confusion .problem burner is the left front .it is a 2 component unit with a 6in. inner section and a 9in. outer section.both sections controled by a single infinity switch by either rotating knob left or right. the inner 6in. section does not operate but the outer 9in section is fully functional. model drawing identifies this burner as 15a with p/n ap3960249. ....your reply recomended replacing the burner with p/n 3960308....which appears to be a 6in. unit used at upper left and right at position 15 in the drawing.......please clarify or correct..thank you.
I do not know who replied to you. I could not find another post by you. I would say that they were incorrect and you need. It would be best to confirm this with a parts representative. Part number: AP3960249
THIS FORUM IS DEAD!!!!!!! |
