desperate des
#1 Posted : Wednesday, December 24, 2014 6:44:22 AM(UTC)
desperate des
reply to previous thread on 12/23 left some confusion .problem burner is
the left front .it is a 2 component unit with a 6in. inner section and a 9in.
outer section.both sections controled by a single infinity switch by either rotating knob left or right. the inner 6in. section does not operate but the outer 9in section is fully functional. model drawing identifies this burner as 15a with p/n ap3960249. ....your reply recomended replacing the burner
with p/n 3960308....which appears to be a 6in. unit used at upper left and
right at position 15 in the drawing.......please clarify or correct..thank you.
#2 Posted : Wednesday, December 24, 2014 7:23:46 AM(UTC)
I do not know who replied to you.
I could not find another post by you.
I would say that they were incorrect and you need.
It would be best to confirm this with a parts representative.
Part number: AP3960249
