jhanson0
#1 Posted : Monday, October 26, 2009 5:25:41 AM(UTC)
jhanson0
I have a Kitchen aid Refridgerator and I'm having a problem with the temp. Both the freezer and the fridge are warming up.Now I'm pretty sure it's either the evap fan, defrost heater or the defrost timer but what I'm not sure about is how to test each one without replacing them all to find the problem...Any suggestions???
#2 Posted : Monday, October 26, 2009 5:57:01 AM(UTC)
Replacement parts for WHIRLPOOL KSRG25FKWH03 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%202220109.pdf
If the compressor and it's fan are working and the evaporator fan is not odds are high that it needs replacing.
You only have a defrost problem if the evaporator coils are heavily iced/frosted up.
Remove the coil cover and check them
If they are heavily coated force a defrost cycle. See the tech sheet.
If the heater heats up then replace the Electronic Defrost Control board.
Be careful, do not burn your fingers.
If it does not heat up it is probably the defrost heater itself or the defrost thermostat. Note may also still be the defrost timer board.
Below are 2 good sites with additional info.
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
