bcantara54
#1 Posted : 10 years ago
bcantara54
My washers agitator is working but the tub it self is not spinning at all. I am just getting soaked cloths the belt is spinning and the transmission is spinning . I recently changed the tubseal about two months ago and everything has been fine til yesterday
bcantara54
#2 Posted : 10 years ago
bcantara54
while retracing what i did to replace the tub seal I notice the washer agitator coupler has metal chips in it
bcantara54
#3 Posted : 10 years ago
bcantara54
IF the transmission is broke could the agitator still spin even though the tub wont?
fairbank56
#4 Posted : 10 years ago
fairbank56
Groups: Expert
If the transmission is spinning, then the transmission is not the problem. Sounds like a problem with the split washer and/or tub nut. Did you use a spanner wrench and hammer to tighten the tub nut?
Eric
bcantara54
#5 Posted : 10 years ago
bcantara54
I dont think he used a spanner wrench.
