APPLIANCEDUDE1972
#1 Posted : Saturday, December 13, 2014 10:40:47 AM(UTC)
APPLIANCEDUDE1972
Whirlpool accurate stove bake button not working all the time, how can I check if it's button on panel or control board issue?
#2 Posted : Sunday, December 14, 2014 12:40:42 AM(UTC)
Parts for Whirlpool GY396LXPQ01 Range - AppliancePartsPros.com
As far as I know there is no way to check it unless you can find a pin out for the control panel/keypad.
Also it is intermittent so odds are high that it will work when you try to check it.
Looks like holding the bake button for 5 seconds puts the unit into the oven calibration mode so if that works all the time I would try the control board first.
If it is also intermittent then try the control panel first.
In any case either one is a gamble.
Maytag Oven Bake button not working (Oven Repair (including Ranges and Cooktops))
by Karin Feeney 12/28/2011 12:20:04 PM(UTC)
