Burners work normally, but Frigidaire convection oven doesn't. Bake, broil, preheat, clean - all are non-working. Found a thread that seems to suggest I need to buy two parts to fix the issue: http://forum.appliancepartspros...-not-heating-up-all.htmlHowever, when I look at the back of the thing, I see two circuit board looking things - a smaller tan one on top of a larger green one. I haven't seen any info about this as I've snooped around a little. I'm very technically challenged, so I'm a bit confused as to if I would need to replace both these boards or just one... Thought I posted about this a couple hours ago, but it's not showing up - apologies if it's a double post. Frigidaire FEFL79JSA
THIS FORUM IS DEAD!!!!!!! |
