Steve Millikan
#1 Posted : Wednesday, December 10, 2014 8:16:08 PM(UTC)
Steve Millikan
Burners work normally, but Frigidaire convection oven doesn't. Bake, broil, preheat, clean - all are non-working.
Found a thread that seems to suggest I need to buy two parts to fix the issue:
http://forum.appliancepartspros...-not-heating-up-all.html
However, when I look at the back of the thing, I see two circuit board looking things - a smaller tan one on top of a larger green one. I haven't seen any info about this as I've snooped around a little. I'm very technically challenged, so I'm a bit confused as to if I would need to replace both these boards or just one...
Thought I posted about this a couple hours ago, but it's not showing up - apologies if it's a double post.
Frigidaire FEFL79JSA
#2 Posted : Thursday, December 11, 2014 12:53:04 AM(UTC)
Parts for Frigidaire FEFL79JSA Range - AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/p...ingfield/316519936en.pdf
If the unit stays in pre-heat and the wiring to/from the control board to the elements and power are OK then odds are that the control board (item F20 in Section 03) is bad.
You may also need a new overlay item 20A. Looks like it is peel and stick and they often get ruined trying to remove them.
If the oven shows that it is ready then it may be the oven sensor.
It should read about 1100 ohms at room temperature.
