-X-
#1 Posted : 10 years ago
-X-
Help. I've had this issue for about 3 years, only deciding now to try and fix.
90% of the time the Blower Hums. The shaft does spins freely, so I can turn the blower on and spin the shaft and the blower works. It also works randomly about 10% of the time.
I've pulled the motor out, everything is clean.
I've read that it might be a capasitor issue, but not sure.
Thanks in advance for the help.
#2 Posted : 10 years ago
Parts for Maytag JES9860BAS19 Range - AppliancePartsPros.com
I do not think this motor has a capacitor so I would say that the motor is bad.
File Attachment(s):
JES9860.pdf (1,624kb) downloaded 4 time(s).
