erincg3
#1 Posted : Tuesday, December 9, 2014 1:51:32 PM(UTC)
erincg3
My range started displaying the F3 E2 error code. I replaced the sensor and still get the same error code. Does this mean the control board needs replacing? Is this something that as a home owner, I can do or should I call a repair technician? Is this a repair that is worth it? Or is this a repair that warrants a new range?
Thanks,
Erin
#2 Posted : Wednesday, December 10, 2014 2:34:21 AM(UTC)
Parts for Whirlpool RF368LXMQ0 Range - AppliancePartsPros.com
[COLOR="Blue"]Does this mean the control board needs replacing?[/COLOR]
That is the most likely cause.
if you purchase it from AppliancePartsPros and it does not fix the problem they will let you return it.
Please see their return policy.
[COLOR="Blue"]Is this something that as a home owner, I can do or should I call a repair technician?[/COLOR]
Depends how handy you are.
If you click on a part's description or picture often a new page will open with info that may help you install the part.
Just be sure to remove power from the unit when working on it.
[COLOR="Blue"]
Is this a repair that is worth it? Or is this a repair that warrants a new range?[/COLOR]
Again I cannot say.
Depends on what shape the unit is in.
Also how much you like the unit.
Also what a replacement unit that you would be happy with would cost.
