My range started displaying the F3 E2 error code. I replaced the sensor and still get the same error code. Does this mean the control board needs replacing? Is this something that as a home owner, I can do or should I call a repair technician? Is this a repair that is worth it? Or is this a repair that warrants a new range?
Thanks, Erin
Here are your parts Parts for Whirlpool RF368LXMQ0 Range - AppliancePartsPros.com[COLOR="Blue"]Does this mean the control board needs replacing?[/COLOR] That is the most likely cause. if you purchase it from AppliancePartsPros and it does not fix the problem they will let you return it. Please see their return policy. [COLOR="Blue"]Is this something that as a home owner, I can do or should I call a repair technician?[/COLOR] Depends how handy you are. If you click on a part's description or picture often a new page will open with info that may help you install the part. Just be sure to remove power from the unit when working on it. [COLOR="Blue"] Is this a repair that is worth it? Or is this a repair that warrants a new range?[/COLOR] Again I cannot say. Depends on what shape the unit is in. Also how much you like the unit. Also what a replacement unit that you would be happy with would cost. |
THIS FORUM IS DEAD!!!!!!! |
