jamie_pancake@yahoo.com
#1 Posted : Wednesday, December 3, 2014 4:41:13 AM(UTC)
About once a week this customer says that her washer makes large holes in some clothes. I have seen them. The bellows has recently been changed. Could that be the problem? Or could it be the matching dryer? Both seem okay. Nothing unusual.
Any suggestions?
sidfink43
#2 Posted : Thursday, December 4, 2014 3:19:40 PM(UTC)
sidfink43
Gosh there really isn't anything I know of to make holes. It could be that a vane is loose and that clothing catches in the gap between the basket and vane but that would produce a rip, not holes.
I would take off the top of both the washer and dryer and examine them from the outside, maybe a screw or small nail that cannot be seen from looking at the inside is present.
thorning
#3 Posted : Tuesday, December 16, 2014 4:51:26 AM(UTC)
thorning
Recently I worked on a dryer that had the stainless steel drum start to split along a seam. If clothing is caught on something like this it will tear up clothes in a hurry. This drum is made from very thin material and the weld seam is prone to split after a couple of years of use. I was able to repair it but if not caught in time it will not be repairable.
