jaywilson
#1 Posted : 15 years ago
jaywilson
My Maytag model #LAT9605AAE is leaking oil (yellowish oil and brown grease) from underneath. It is also making a VERY loud banging noise during the spin cycle. With the front cover removed, the motor assembly is bouncing but the banging is coming from underneath. Any ideas???? Thank you.
sidfink43
#2 Posted : 15 years ago
sidfink43
Itg sounds very much like your transmission has failed. The lubricating oil probably leaked out and caused the problem.
Given the age of your machine I would think a replacement would be in order.
#3 Posted : 15 years ago
I would remove the front panel,tilt the washer back, remove the belts and turn the tranny pulley in the spin direction to see if the problem is the tranny. If ok, I would look for busted snubber shoes, a busted tranny support spring, or a bad motor mount.
