JAD315
#1 Posted : Tuesday, November 25, 2014 7:28:20 AM(UTC)
JAD315
Jenn-air convection wall oven went completely dead after power outage. No clock, no lights, no error codes. Built in microwave above works fine. Both run off of same breaker. Does this mean the control board is shot?
#2 Posted : Tuesday, November 25, 2014 10:07:02 AM(UTC)
Parts for Jenn-Air JMW9527DAB Oven - AppliancePartsPros.com
See the attachment for the wiring diagram
[COLOR="Blue"]Does this mean the control board is shot?[/COLOR]
Not necessarily.
Looks like the microwave runs off of the L2 side of the line (red)
The stove control board runs off the L1 side of the line (black)
So I would check the power, first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
JMW9527.pdf (467kb) downloaded 15 time(s).
Whirlpool Wall Oven Dead After Self Cleaning Cycle (Oven Repair (including Ranges and Cooktops))
by Mattstone87 10/25/2019 3:45:35 PM(UTC)
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 1/19/2018 1:24:46 PM(UTC)
Wall Oven Dead after self cleaning (Oven Repair (including Ranges and Cooktops))
by PKABS1 8/1/2014 6:05:10 PM(UTC)
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 2/9/2008 8:02:27 AM(UTC)
Jennair wall oven dead - which part? (Oven Repair (including Ranges and Cooktops))
by riverwalker 12/12/2007 5:37:56 AM(UTC)
