APPLIANCEDUDE1972
#1 Posted : 10 years ago
APPLIANCEDUDE1972
where can I find just the motor for the timer? I want just the motor not the whole timer assembly.
thorning
#2 Posted : 10 years ago
thorning
Unless someone else provides some info that is new and different the motor section of the timers used on washers and dryers is not available as a separate part. I have taken a few off timer assemblies and almost all of them I have ever seen operate using 110 volt. Be aware that some run CW and some run CCW. A possible source if you need one is a used appliance supply shop. I also have a few used timers in my junk box if you are desperate for one. These timers are all from dryers not washers but the small drive motors are almost all the same. You can contact me at my home e-mail jaybird@mtco.com if you want to try one.
APPLIANCEDUDE1972
#3 Posted : 10 years ago
APPLIANCEDUDE1972
I will count gear teeth on both gears and email you a pic thanks a lot! Im going to try a local electronics store here as well, they always seek tohave small hard to find electrical items
thorning
#4 Posted : 10 years ago
thorning
There is a used appliance and salvage place here in our area also. They are located in Peoria ,Illinois. The phone number is 309 655 0909. I have found stuff there but they are not really knowledgeable and almost always ask for the customer to bring the old part in to their store to see if they can match it. I can take a photo of one of my timers and/or motors if you want. let me know your e-mail address if you would like a couple of pics.
APPLIANCEDUDE1972
#5 Posted : 10 years ago
APPLIANCEDUDE1972
timer motor doesn't stop running (Dryer Repair)
by bakmjk 13 years ago
Washer timer motor in timer assembly (Washer Repair)
by marinekilz 13 years ago
Timer or Timer Motor? (Washer Repair)
by lstuewe 14 years ago
Test Timer motor/switch (Dryer Repair)
by armackzum 15 years ago
Is my timer motor broken? (Dishwasher Repair)
by minervajeanne 16 years ago
timer motor, please help find part (Washer Repair)
by howlys 16 years ago
Looking for source of timer motors (Washer Repair)
by philipsb 17 years ago
Roper dryer - 95 volts on timer motor (Dryer Repair)
by jazbird1 18 years ago
