where can I find just the motor for the timer? I want just the motor not the whole timer assembly.
Unless someone else provides some info that is new and different the motor section of the timers used on washers and dryers is not available as a separate part. I have taken a few off timer assemblies and almost all of them I have ever seen operate using 110 volt. Be aware that some run CW and some run CCW. A possible source if you need one is a used appliance supply shop. I also have a few used timers in my junk box if you are desperate for one. These timers are all from dryers not washers but the small drive motors are almost all the same. You can contact me at my home e-mail jaybird@mtco.com if you want to try one.
I will count gear teeth on both gears and email you a pic thanks a lot! Im going to try a local electronics store here as well, they always seek tohave small hard to find electrical items
Originally Posted by: APPLIANCEDUDE1972  I will count gear teeth on both gears and email you a pic thanks a lot! Im going to try a local electronics store here as well, they always seek tohave small hard to find electrical items There is a used appliance and salvage place here in our area also. They are located in Peoria ,Illinois. The phone number is 309 655 0909. I have found stuff there but they are not really knowledgeable and almost always ask for the customer to bring the old part in to their store to see if they can match it. I can take a photo of one of my timers and/or motors if you want. let me know your e-mail address if you would like a couple of pics.
