DeltaFox
#1 Posted: : Saturday, November 22, 2014 10:16:36 AM(UTC)
DeltaFox
The large burner on my stove quit working in the middle of cooking dinner. I was heating a pot at high heat, then turned off the burner. When I turned the burner on a few minutes later the indicator light lit up, but the burner did not heat. It hasn't heated up since.
Please help!
#2 Posted : Sunday, November 23, 2014 2:22:22 AM(UTC)
Parts for RF199LXH - AppliancePartsPros.com
The model number looks incomplete so you wuill have to choose the correct model in the "Matching Model Numbers" section.
Unplug the unit and check the element with a meter.
If open (infinite ohms) then replace it.
If OK then replace the control (infinite) switch
