The large burner on my stove quit working in the middle of cooking dinner. I was heating a pot at high heat, then turned off the burner. When I turned the burner on a few minutes later the indicator light lit up, but the burner did not heat. It hasn't heated up since.
Please help!
Here are your parts Parts for RF199LXH - AppliancePartsPros.comThe model number looks incomplete so you wuill have to choose the correct model in the "Matching Model Numbers" section. Unplug the unit and check the element with a meter. If open (infinite ohms) then replace it. If OK then replace the control (infinite) switch |
THIS FORUM IS DEAD!!!!!!! |
