Below are your parts, includes a wiring diagram but it is not very clear.
Parts for Frigidaire FAQE7001LW0 Dryer - AppliancePartsPros.comThe above is for a FAQE7001LW0
I think this is your unit and in the given model number there area couple errors. The i is actually a 1 and the o is actually a 0.
There is not a thermal fuse in this unit that will kill power to the unit's motor.
Does the drum light work?
If not, I would start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
