problems
#1 Posted : Monday, November 10, 2014 4:40:42 PM(UTC)
problems
I have a Frigidaire side by side that is 9 years old. It will randomly defrost the freezer and then refreeze. Then the refrigerator will get warm after the freezer defrosts. Please Help
#2 Posted : Tuesday, November 11, 2014 1:45:25 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
problems
#3 Posted : Thursday, November 13, 2014 5:35:29 AM(UTC)
problems
Frigidaire model # FFSS2614QE
I unplugged it and let it sit for few minutes and then plugged back it in and freezer and refrigerator started working again. I an under the assumption that something is going out and unplugging it will only work so long. Please Help.
#4 Posted : Thursday, November 13, 2014 12:27:49 PM(UTC)
Here is the tech sheet
http://manuals.frigidaire.com/p...f/Anderson/808662201.pdf
This model number does not come up on AppliancePartsPros though I am sure that they will have parts for it.
Sounds like a control board problem but I would go through the diagnostics to see if anything else pops up.
If all OK then I would replace the board.
I am assuming that there are no other symptoms (clicking etc.)
