The dishwasher will start and fill, then it stops and the normal cycle light/button blinks steadily. None of the touch pad "buttons" work while this is going on, nor will the two buttons on the front of the dishwasher.
The only other lights that illuminate are the two horizontal "dashes on the front where the cycle timer appears.
I disconnected power for 30 minutes and It will re-start and only get to the same point and stop again.
Any suggestions before I start replacing parts?
