replace the detergent dispenser for my dishwasher? :confused: i may also be contacted at: dwalkup29@gmail.com
Below is what comes up when I search using the given model number. Parts for KUDS035TSS0 - AppliancePartsPros.comThe number seems incorrect so you will have to choose one from the Matching Model Numbers section I think the 5 should be an S. Not sure about the rest of it. If you click on a part's picture or description a new page will open with info about that part. It may have a Q&A section and perhaps even a viodeo that should be useful to you. |
THIS FORUM IS DEAD!!!!!!! |
you're absolutely correct about the model number...seems i can't read/write correctly....thanks...
