donw29
#1 Posted : Monday, November 10, 2014 10:43:57 AM(UTC)
donw29
replace the detergent dispenser for my dishwasher? :confused:
i may also be contacted at: dwalkup29@gmail.com
#2 Posted : Tuesday, November 11, 2014 12:29:34 AM(UTC)
Below is what comes up when I search using the given model number.
Parts for KUDS035TSS0 - AppliancePartsPros.com
The number seems incorrect so you will have to choose one from the Matching Model Numbers section
I think the 5 should be an S.
Not sure about the rest of it.
If you click on a part's picture or description a new page will open with info about that part. It may have a Q&A section and perhaps even a viodeo that should be useful to you.
donw29
#3 Posted : Tuesday, November 11, 2014 9:56:50 AM(UTC)
donw29
you're absolutely correct about the model number...seems i can't read/write correctly....thanks...
