I have a whirlpool condenser fan motor that runs but is noisy .I know if you pull up and down on on the motor shaft you should not get any play.This motor shaft has a lot of horizontal play is this normal and would it cause vibrations.Thank you
THIS FORUM IS DEAD!!!!!!! |
