Wire22
#1 Posted : Monday, October 27, 2014 12:18:24 AM(UTC)
Wire22
I have a whirlpool condenser fan motor that runs but is noisy .I know if you pull up and down on on the motor shaft you should not get any play.This motor shaft has a lot of horizontal play is this normal and would it cause vibrations.Thank you
#2 Posted : Monday, October 27, 2014 1:37:21 AM(UTC)
Parts for Whirlpool ET18GKXDW05 Refrigerator - AppliancePartsPros.com
There should not be a lot of slop in the armature bearing.
I would replace the fan ( item 40 in section 04)
Click on the parts description or picture for more info on it.
