my kenmore washer wont fill up with water, it stops between, and when it does throw water its hot. the cold or warm water dont work, everything else works fine the spin cycle works.. its only the water problems... please help asap!!! 😒😡
Groups: Expert
Disconnect hoses from washer, direct cold water hose into tub and turn wall valve on to make sure cold water flow is ok. Check for clogged screens inside the water valve inlets at back of washer and any screens in the hose ends. If all good, we need the washer model number to be of any further help.
Eric
