dvazquez
#1 Posted : Saturday, October 25, 2014 11:40:04 AM(UTC)
dvazquez
my kenmore washer wont fill up with water, it stops between, and when it does throw water its hot. the cold or warm water dont work, everything else works fine the spin cycle works.. its only the water problems... please help asap!!! 😒😡
fairbank56
#2 Posted : Saturday, October 25, 2014 11:59:05 AM(UTC)
fairbank56
Groups: Expert
Disconnect hoses from washer, direct cold water hose into tub and turn wall valve on to make sure cold water flow is ok. Check for clogged screens inside the water valve inlets at back of washer and any screens in the hose ends. If all good, we need the washer model number to be of any further help.
Eric
Kenmore 500 Washer - No Warm (hot/cold work) (Washer Repair)
by Old&Slow 6/17/2017 2:17:04 PM(UTC)
