This unit is one with french doors and bottom freezeer with ice-maker in the refrig. section. Everything in the refrig. section is freezing. There is no tech. sheet to be found to run a diagnostic test. Can you help?
Here are your parts. You will have to choose a unit in the Matching Model Numbers section. Parts for MFI2266AES - AppliancePartsPros.comSee the attachment for the tech sheet. Run the diagnostics to see if the damper opens/closes. |
THIS FORUM IS DEAD!!!!!!! |
