jamie_pancake@yahoo.com
#1 Posted : Friday, October 24, 2014 11:09:45 AM(UTC)
This unit is one with french doors and bottom freezeer with ice-maker in the refrig. section. Everything in the refrig. section is freezing. There is no tech. sheet to be found to run a diagnostic test. Can you help?
#2 Posted : Saturday, October 25, 2014 12:16:13 AM(UTC)
Here are your parts.
You will have to choose a unit in the Matching Model Numbers section.
Parts for MFI2266AES - AppliancePartsPros.com
Run the diagnostics to see if the damper opens/closes.
File Attachment(s):
MFI2266.pdf (286kb) downloaded 16 time(s).
