In case this helps anyone in the future, I figured I would post what I was able to find.
The Primary valve provides water to the filter. The secondary valve provides water to the water dispenser and to the ice maker.
By replacing the secondary valve (Item 18 in the schematic), I was able to fix my frozen ice maker feed tube issue.
The part was an exact match and only took about 15 minutes to install and test.
Within a few minutes of installation, I was once again making ice.
